Re: Installing options(?) for an 8N10000 generator on a 1941 9N
Posted by deanostoybox on October 19, 2021 at 04:44:15 [URL] [DELETE] :
In Reply to: Re: Installing options(?) for an 8N10000 generator on a 1941 9N posted by Lou Puls on October 18, 2021 at 23:54:51:
"So it seems obvious the then-common (F)-(G)-wire is connected to the grounded base of the 9N-10505A Cut-Out and the (A)-wire to its GEN-terminal opposite to its BAT-terminal."
As long as the (F)-(G) terminals are connected together it should work fine and be all that is necessary. In the previous versions of the three brush generator that connection is made internally. Adding a wire tying those terminals to the grounded base of the cutout would certainly not hurt anything, and I would not hesitate to do so. It would help to insure the integrity of of the ground connection between those points.
