Re: Fire Extinguisher
Posted by Steve Dabrowski on October 16, 2021 at 15:26:53 [URL] [DELETE] :
In Reply to: Fire Extinguisher posted by raski on October 09, 2021 at 10:22:47:
I mount one on the bracket that I made for my slow vehicle triangle which I mount to the rear bolt holding the seat assembly to the top of the hydraulic actuator. I just used a long steel angle strap that is about an inch or less wide and about a quarter inch thick, drilled it to mount the triangle and then the fire extinguisher on the other side facing the seat. I bent the piece in a vise so it angles up from the seat mount to clear the spring and attachment point and then rises straight up. Works great and uses only a single easily reached nut to hold it in place.
