Re: early 1939 ignition switch
Posted by carl on October 12, 2021 at 17:11:25 [URL] [DELETE] :
In Reply to: Re: early 1939 ignition switch posted by Gary Johnson on October 12, 2021 at 13:10:49:
Forget your s/n. Might be a '39 Block but the rest says later 41. If your start pushbutton isn't on the LH Dash and the Key Switch isn't on the RH Dash, it isn't a '39 dash anyway. When they moved the key switch to the LH steering column, so did the pushbutton. If you go to my first post I link the switch you need from JUST8Ns. See PIX
