Re: Front wheel 8N compatibility with NAA
Posted by Carl on September 14, 2021 at 05:37:31 [URL] [DELETE] :
In Reply to: Front wheel 8N compatibility with NAA posted by Mark M on September 12, 2021 at 20:13:01:
Dust off your 39-53 mpc and look up the info. The 8N began the 6" bolt hole pattern using 6 wheel hub studs on the front. They were used all through the Hundred Series Models as well. The wheels and tire sizes don't matter, they fit all weather 4 x 19 or 5.5 x 16 -it's the hub hole spread that matters.You can pick up your neighbors NAA wheels and they will swap out on your 8N. And yes the spindles and parts all interchange as well. I'd see what else you can salvage off teh NAA if he is scrapping it out. Good, usable Original parts bring good money
