Re: Coil spring seat on 2N
Posted by carl on September 07, 2021 at 06:31:25 [URL] [DELETE] :
In Reply to: Re: Coil spring seat on 2N posted by dave#1 on September 06, 2021 at 21:46:53:
Yes Dave the Monroe EZ-Ride seat was only rated for 150 pounds payload. The Knoedler was a little better and then the Ford Rest-O-Ride was better yet. All required that you remove your tractor standard OEM pan seat and install it on the new model. It seems to me that half the problem with the seat is sitting on that solid steel pan. The spring on my N's works fine and I use a foam-padded FORD logo seat cover and it helps.
