Re: Stopped charging
Posted by JMOR on August 23, 2021 at 16:55:53 [URL] [DELETE] :
In Reply to: Re: Stopped charging posted by Robert on August 23, 2021 at 14:56:33:
Identify which terminal on regulator is BATT, ARM, and Field. Start engine at fast idle or better & connect BATT to ARM with jumper. If ammeter shows charge with jumper but not without, the regulator cut out function is not working. If no increase in ammeter occurs, then with that jumper remaining in place, connect a jumper from FIELD to regulator ground or other good chassis ground and again observe ammeter. Remove jumpers before shutting off engine. Report back & we see where to next.
