Re: 9N won’t crank
Posted by J Stortz on August 20, 2021 at 21:00:40 [URL] [DELETE] :
In Reply to: 9N won’t crank posted by J Stortz on August 11, 2021 at 22:47:44:
Got the old girl started today. This is what I did. I changed the start switch and had no change in the ability to crank the tractor. At this point I am thinking a bad starter;so I took starter off and took it to a shop to have checked out. The shop said it looked new inside so didn’t do anything to it. I found the resistor board had fallen apart so changes that even though I knew it wouldn’t change the cranking ability. Finally I remove the battery and cleaned up the ground point on the tractor. Reinstalled battery and bam she cranked and started. Music to my ears.
