Re: starter solenoid problem
Posted by Carl on August 20, 2021 at 06:31:49 [URL] [DELETE] :
In Reply to: starter solenoid problem posted by thad on August 19, 2021 at 23:52:43:
Donít use wire colors to trace wiring. There was no white wire in the original wiring harness. A clicking solenoid usually means the battery is weak or dead. Get it tested at a shop. Use you diagrams to verify wiring while battery is being tested. The starter motor is wired the same on both the early and the later 8N.
8n wiring
