Re: Timing a Side Distributor
Posted by JMOR on August 14, 2021 at 09:42:24 [URL] [DELETE] :
In Reply to: Timing a Side Distributor posted by Terry in Mo (T-Mo) on August 14, 2021 at 09:27:19:
Easiest is by ear/trial & error. I used the #4 "on the rock" valves position to determine #1 TDC-compression stroke and filed a notch in belt pulley that aligns with engine block casting feature. Based on circumference, you can then mark off various degrees on pulley.
