Timing a Side Distributor
Posted by Terry in Mo (T-Mo) on August 14, 2021 at 09:27:19 [URL] [DELETE] :
I have a 8N that has a 9N engine on it. Someone has replaced the front mount distributor with a side distributor. Since it's a 9N engine, it does not have the access hole on the right rear of the engine to see the timing marks on the flywheel. I'm pretty sure it's out of time. My question is, what is the procedure to set the timing on this? Thanks.
