Re: 9N won’t crank
Posted by Carl on August 12, 2021 at 09:18:41 [URL] [DELETE] :
In Reply to: 9N won’t crank posted by J Stortz on August 11, 2021 at 22:47:44:
Fuel, Spark. Combustion. Usually one or both of the first two. You were able to start/run off of your jumper vehicle. New battery means nothing -get tested. 6V means nothing if not wired correctly. Due the fuel flow test first.
carl
