Re: 8N camshaft thrust washer
Posted by McNugget on August 09, 2021 at 11:08:41 [URL] [DELETE] :
In Reply to: 8N camshaft thrust washer posted by ChrisJ on August 06, 2021 at 13:12:58:
If you get a washer make sure to check the fit. I recall it is a stamped, sheet metal part. The spring "fingers" can be set too far out causing too much pressure on the cover. The result is a damaged cover and metal shavings in the system that ruins the crank bearings. Set the springs to position the washer to just touch the cover. From my experience, may yours be different...
