Re: 601 workmaster 1957?"
Posted by TheOldHokie on July 31, 2021 at 16:08:05 [URL] [DELETE] :
In Reply to: 601 workmaster 1957? posted by Earl on July 31, 2021 at 15:25:30:
A working coil will "fire" if it receives primary voltage (12v in your case) and you interrupt that voltage. Check the primary voltage and verify that it gets interupted. Put your spark checker on the coil and you can confirm the coil is good.
TOH
