Re: Made the swap for a 50 8N
Posted by TheOldHokie on July 26, 2021 at 14:57:34 [URL] [DELETE] :
In Reply to: Re: Made the swap for a 50 8N posted by Terry in Mo (T-Mo) on July 26, 2021 at 06:06:19:
There were three different filler tubes used. Sounds like you have the long one used on early engines. See if you can find one of the shorter ones. It will fit the hole fine and probably fix most of your problem.
TOH
