Re: Can't shift Combination Sherman Transmission
Posted by Kirk-NJ on July 25, 2021 at 04:50:22 [URL] [DELETE] :
In Reply to: Can't shift Combination Sherman Transmission posted by Don Haskins on July 24, 2021 at 07:21:19:
I've done one once on an 841. It was a fight to get it out and twice the fight to get it lined up and back in. I would not do it again cause it's easier to split the tractor IMO. Depending on which generation sherman you have if top cover has exposed rails you might be able to spray some PB blaster or kroil on them and then lightly tap the shifter with a hammer to see if you can get it into the neutral detent, then tap in and tap up or down. This will only work if inside rails has not been rusted. Even if you only use one range it pays to shift them into other ranges every once in a while to keep everything operational
