Re: Ready to reinstall pump and PTO shaft
Posted by Mark on July 04, 2021 at 20:21:21 [URL] [DELETE] :
In Reply to: Ready to reinstall pump and PTO shaft posted by Charles Hudson on July 04, 2021 at 09:04:15:
No sealant needed on the gasket, don't recall how thick my gasket was ( I know it wasn't paper thin.
I did wash down the inside of the tranny and cleaned it out , I mixed gunk sc with diesel according to directions on the jug then rinsed it out with clean straight diesel.
Drip dry overnight and assembled next day, used my motorcycle jack to carefully reinstall.
Ether TOH or Hobo had some great tips that are not in the manual (maybe on YT site).
Tip the front up a bit (that goes up and in first ) I put two front bolts in to hold it in place and align the gasket, then lifted the rear up and put in two bolts there as well.
It went very slick no issues and no leaks... This on my 49 8n.
Leave the bolts a tad loose and reinstall pto shaft, finger tight on the bolts on the pump and rotate the pto shaft a few times to line everything up then tighten the bolts on the pump and rotate pto shaft again to be sure everything is ok...
Best of luck
