In Reply to: Re: Freeman 2000, 3000, 3500, 4000 Loader - parts book posted by Greg WI on July 07, 2010 at 10:54:55:
Hi Greg. Should be able to get the owner's manual from the Bush Hog web site - that's where this parts manual came from.
>> when it gets hot it struggles and it will not hold the hydraulics when the tractor is off. I assume that it is a problem in the valves. <<
Yeah, either the pump or control valve may be leaking once the fluid thins out. May just need o-rings if you get lucky.
Posting not permitted in the forum archives.<1278517178">
