In Reply to: Re: Dearborn 10-156 2 bottom 14-inch adjustment posted by jackinok on December 27, 2010 at 15:41:56:
I took some quick measurements. I am at 54-1/2 inches, inside, tire-to-tire. With your figures and technique, I should easily be able to set the plow up with an initial adjustment and then need only to fine tune it from there. I will take your instructions to the next tractor show. There are always guys there trying to plow and having trouble getting the settings correct.
My Newgren is pictured here. The truck has a really large turning radius. I believe Monroe figured mounted implements would work better with the truck than trail behind.
I must apologize to everyone for hijacking the thread away from the original question. I hoped this discussing of adjustments would be of help to a lot of folks.
Clint
Posting not permitted in the forum archives.<1293493400">
