I went to look at the loader you helped identify...this one has a good tag that reads Superior Loader Model H-118-S
It does not have any mounting brackets, front or back. I measured the distance from the front piece that shows the 3 holes in it back to the center of the rear mounting pin hole. It is very close to 79 1/2 inches.
Can you see anything good, bad, ugly with any parts in the pics? Anyone have one of these on a Ford 860 that had the same Model # as this? I found an old post on another tractor site where someone is trying to remove a H-118-S from his Jubilee, so I would guess this came off the Jubilee as Seller said.
If an 860 is about 3 inches longer than the Jube, would it be reasonable to think this loader would need some additional work to fit on a 860?
I am inclined to wait until I find one that I know for sure came off a 800 Series Tractor, and be able to try it out, rather than making an offer on this one....not knowing if it will fit or if everything works out ok.
Any opinions will be more than welcome....
Tim
Posting not permitted in the forum archives.<1290037618">
