In Reply to: Definitely O.T. posted by joe in wilkinson on January 18, 2021 at 16:22:30:
Interesting project. Can you export the the AC-14 file to a format that you can then print on the main computer? Also, you might look at virtual box on the main computer. You can find ready to run image files for virtual box or you install virtual box and then create a machine and install WinXP. Virtual Box machines have access to all the ports of the main machine. You might could also get AC-14 to run on a Linux box directly using WINE. I have plenty of old hardware to play with this if you were closer.
