Re: Walnut tree sales, end of story
Posted by Bruce(OR) on May 11, 2020 at 11:32:45 [URL] [DELETE] :
In Reply to: Re: Walnut tree sales, end of story posted by 2Ntony on May 09, 2020 at 07:32:43:
If you had Doug Fir, your largest diameter would be 32 inches for the local mills.
After that it either becomes a log cabin log or an export. Log cabin logs being in excess of 100'. Your smaller tooth picks will gain in value while the large one might start to rot from the inside out. That you won't know until you whack it.
Best of luck. Oh, figure 10/15% for taxes. Anything over $10K and the IRS gets notified. You can also contact the Small Woodlands Owners Association.
Your not zoned SCCA down there so you don't have that to worry about.
See ya' around some time.
