Re: Engine Cleaner
Posted by Bruce(OR) on November 15, 2019 at 10:06:53 [URL] [DELETE] :
In Reply to: Re: Engine Cleaner posted by Philny on November 11, 2019 at 22:04:06:
If you desire to flush the engine, you can run a qt of Kerosene in with the oil and let the engine run 30 minutes, shut off and drain empty. Change filter and refill.
I have changed out one or two of those and flushing an engine will not remove enough gunk from a VC to matter.
