Re: 1989 Lincoln Steering Pump
Posted by Jack - Iowa on September 15, 2019 at 08:25:13 [URL] [DELETE] :
In Reply to: Re: 1989 Lincoln Steering Pump posted by Bruce(OR) on September 15, 2019 at 01:23:54:
Thank you Bruce! You have likely solved my problem.
Each of the "new" pumps came with a Teflon washer. So I have two.
However they measure .620 OD and .502 ID.
It appears the bore is .562 and the OD of the pipe is .433
Did you possible mean expand in your last line?
I will play with the first washer I received as I have already mis-treated it.
Jack
