Re: 1989 Lincoln Steering Pump
Posted by Jack - Iowa on September 13, 2019 at 08:49:01 [URL] [DELETE] :
In Reply to: Re: 1989 Lincoln Steering Pump posted by Bruce(OR) on September 13, 2019 at 08:08:06:
Of course it is not an "American" re-builder unless we use American to mean anyone in the western hemisphere which technically is correct.
One interesting indication of their concern for quality -- There is a Teflon washer used in the high pressure line connection. The ones included in these installation kits are over sized! Of no use what so ever! Not only that, due to it's age, Ford no longer has the part available. It just so happens I can buy Teflon tubing, 9/16 OD, 7/16 ID which should work perfectly IF I can figure out how to slice a washer .050 thick off of it.
