Re: Plumbing a Cistern
Posted by mthomas on September 09, 2019 at 07:56:49 [URL] [DELETE] :
In Reply to: Re: Plumbing a Cistern posted by David D. Smith on September 09, 2019 at 06:47:31:
There will be a float switch at the tank, the water will be tested, there is a check valve built into the pump but a second one is a good idea, and I use brass fittings.
The cistern enables me to use a smaller pump, run it for longer durations with fewer starts, and be able to flush when the power goes out. Most wells around here are half this deep, but I know of a few that are hundreds of feet deeper.
