Re: Plumbing a Cistern
Posted by David D. Smith on September 09, 2019 at 06:47:31 [URL] [DELETE] :
In Reply to: Plumbing a Cistern posted by mthomas on September 08, 2019 at 21:44:12:
You will have to have a check valve at the space between the tee and the well head.
Are you going to put a float switch in the tank?
If you use a pressure switch the tank will have to be able to hold pressure.
Are you going to have the water tested for hardness and bacteria?
That is a lot of head lift, You will need a big pump.
From my experience, don't use plastic couplers or check valves on plastic pipe. Use brass couplers.
Dave <*)))><
