Re: Why does water stink?
Posted by steveva on April 05, 2019 at 17:18:45 [URL] [DELETE] :
In Reply to: Why does water stink? posted by Farmer Dan on April 05, 2019 at 05:56:52:
Need to change the anode rod.
Most water heater manufacturers will give you the other one that you need if you just got a new one.
The other issue would be sulfur gas in the water, but that would not just show up as a new issue. It would show up as soon as the well is drilled.
The way to get rid of sulfur gas is to inject air into the inlet pipe with a venturi and then bleed it back out in the bladder tank. the bad smell goes with the air.
