Re: Why does water stink?
Posted by wer-fl on April 05, 2019 at 08:15:37 [URL] [DELETE] :
In Reply to: Re: Why does water stink? posted by Farmer Dan on April 05, 2019 at 07:32:11:
Should be located under the plastic plug/cover on top the heater. When you pull the plastic plug you will need to clear the excess foam insulation. My hot water heater smelled bad, the cold water inlet pipe acted as the next sacrificial anode and started to leak when it dissolved.
Woody
