Re: Help finding hardware
Posted by Tim Daley(MI) on January 05, 2019 at 08:18:42 [URL] [DELETE] :
In Reply to: Help finding hardware posted by Farmer Dan on January 05, 2019 at 06:45:00:
Daniel-
I’ve used CENTURY SPRINGS a few times; they usually carry a stock part I need. They have some 2” ID springs, but note that the smallest wire diameter part is .078”, or 2mm. From there the wire diameter increases substantially going up to 1.0” and over. That’s a pretty HD spring and would take a heck of lot of force/load to compress. Even a 2mm wire diameter is going to be robust. You can also try WB Jones and Michigan Spring Steel Co. There are alternative materials as well -plastic, copper, brass, bronze, and others.
