Re: truck window stuck Here is the link.
Posted by lonestarjeff on December 26, 2018 at 00:16:40 [URL] [DELETE] :
In Reply to: Re: truck window stuck Here is the link. posted by steveVa on December 23, 2018 at 23:29:58:
LoL, I just now see your response. The motor & regulator assembly on mine was riveted to the door, so drilled them all & pulled it out. The motor, of course, started working again as soon as I pulled it out. I scrounged up several mismatch hex screws, washers, & nuts to bolt the assembly back into the door.
Since the two shoes had pulled lose from the glass I had to clean off old adhesive residue from everything & re-glue. I used E6000, mounted the shoes on the glass, & rolled it to the top. We'll see how it holds after leaving it up a couple of days.
