Re: truck window stuck Here is the link.
Posted by steveVa on December 23, 2018 at 23:29:58 [URL] [DELETE] :
In Reply to: Re: truck window stuck posted by steveVa on December 23, 2018 at 23:07:19:
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.youtube.com/watch%3Fv%3D8jA37CnHYwo&ved=2ahUKEwjQxuX4y7ffAhWHpFkKHUXBCRgQjjgwB3oECAEQAQ&usg=AOvVaw3ACw7docivCnL4eCB-MXmk
Here is the link.
The thing I found was that the hole drilled was bigger then 3/8 to get to the bolts that hold the window motor. There are 2 indented places on the door where you drill. Then I just loosened the three bolts that hold the motor and then hit the down switch. Then I just put the window lifter down a third so I could glue the glass back into the U tabs.
5hen I raised the window up but I tightened the window motor bolts first. Then I pushed th window up tight so the window seats well in the U while the glue dries.
Hope this helps.
