Re: truck window stuck
Posted by steveVa on December 23, 2018 at 23:07:19 [URL] [DELETE] :
In Reply to: truck window stuck posted by lonestarjeff on December 23, 2018 at 20:34:53:
Mine has done this twice before. There is a youtube video that tells how to fix it. You need to drill a hole where the window motor is mounted so you can loosen the motor to get it un jambed. It is easier then it sounds at first. I will se if I can find a link to the video. If I remember correctly, the trick is to loosen the bolts, but not to take them all the way out.
