Re: Shed moving part 2.
Posted by mthomas on September 08, 2018 at 22:44:33 [URL] [DELETE] :
In Reply to: Shed moving part 2. posted by Island Mike on September 06, 2018 at 15:12:17:
If you angle your roller logs you will be able to steer somewhat. If you angle the right side of the roller forward and pull straight ahead you should see the shed turn to the left. The opposite is also true.
I just moved a 24X36 house on pipe rollers. I did not have as far to go as you.
