Re: Barn hydrant
Posted by steveVa on September 04, 2018 at 07:46:14 [URL] [DELETE] :
In Reply to: Barn hydrant posted by NTP on September 04, 2018 at 06:42:41:
The rod is adjustible. You might get the leak to stop by adjusting th rod down a little. That has worked in the past.
Is the hydrant working otherwise? If it is comming on and letting water through, the rod should pull right out. Did you un screw the head, and the rod won't pull up?
