Barn hydrant
Posted by NTP on September 04, 2018 at 06:42:41 [URL] [DELETE] :
I need to rebuild the hydrant as it allows water to seep out of the valve at the bottom of the hydrant causing my pump to kick on. I can't get the long rod to come out to put a new tip on it. I have rebuilt this hydrant before and the rod simply pulled out. The hydrant works normally except for the leak. Not wanting to break something down there, any suggestions as to how to remove the rod?
