Re: ethanol again
Posted by dave#1 on August 28, 2018 at 10:40:10 [URL] [DELETE] :
In Reply to: Re: ethanol again posted by Mower on August 27, 2018 at 11:32:25:
I'd say consider yourself lucky !
Pretty sure just about everyone on the planet has had problems of some sort, If you had a engine that was built before Ethanol, You should have had problems when Ethanol came out, Fuel lines, small engine primmer bulbs, Carb issues.....I have had problems with carb boots on our snowmobiles that had cracked due to Ethanol, The replacement upgraded boots are "Ethanol friendly"
I'm sure all "New " engines made now have all new Ethanol friendly components so now you won't see as many problems as before (Unless it was your stuff) (-;
later,dave
