block test
Posted by lonestarjeff on August 14, 2018 at 23:32:32 [URL] [DELETE] :
Picked up a block tester yesterday to see if I can detect any evidence of a gasket leak into the coolant. I've run two tests so far(both negative)....one I ran on the cold engine this morning, the second time after getting back home on it while hot.
The truck did not overheat today & I had not driven it since last week, so I guess I will try running the test after the next time it overheats on me. No idea how long the trace of exhaust is detectable in the coolant.
