Re: F-150 still overheating
Posted by dave#1 on July 26, 2018 at 08:48:12 [URL] [DELETE] :
In Reply to: Re: F-150 still overheating posted by Kurt in Iowa on July 26, 2018 at 06:55:07:
Agreed, Check for a bad head gasket or cracked cylinder head, I've run across it 3 times , once with one of our Caravans, a friends car and the Volvo pay loader I drove at work, We had bought a Combustion Leak Detector to test the loader, very easy to use and fairly cheap.
Water pumps rarely stop pumping, usually the seals go bad and then leak out the weep hole in the bottom of the pump.
HTH
later,dave
