Re: Wheel Hub Nuts
Posted by Larry TX on May 04, 2018 at 11:09:06 [URL] [DELETE] :
In Reply to: Wheel Hub Nuts posted by g ostby on May 04, 2018 at 10:48:58:
If it's wheel lug nuts you're referring to, once the threads are thoroughly cleaned, a few drops of light oil (motor oil is just fine) on the threads should suffice. Don't think you'd ever want to use Loc-tight on a lug nut, particularly on the wheels of a slow moving wagon.
