Re: Tire Guards
Posted by Dean on February 28, 2018 at 23:12:40 [URL] [DELETE] :
In Reply to: Tire Guards posted by steveVa on February 28, 2018 at 19:47:29:
Are you speaking of "tire liners?"
I use tire liners in tube type tractor tires that are used in areas where thorns are present. They work absolutely wonderfully to protect against thorn punctures but are not intended to protect against wire, glass, nails, screws, etc.
They are sections of old tires that have been ground down to fit inside the tire between the tube and the inside of the tire casing. They continually move slightly during use and continue to shear off the sharp end of thorns as they work their way through the tire.
I've not had a single thorn puncture since I started using them about thirty years ago.
Though once common, they are now hard to find but I do believe that Gemplers handles them.
Message: To add a single image to your post, click here. To add multiple images to your post, click here. Optional Link URL : Link Title : Website Title Optional Image URL:
