Re: Is it a Hardie orPritchel Hole
Posted by BlasterStumps on January 28, 2018 at 20:54:01 [URL] [DELETE] :
In Reply to: Re: Is it a Hardie orPritchel Hole posted by 36 coupe on January 28, 2018 at 19:35:13:
Thanks 36 for that idea. I might give that a try. I was contemplating using a 3/4" drill bit with a reduced shank, cutting it off and then grinding (slowly like you mentioned) the cutting edge.
Dang blacksmith type stuff is expensive. $30 or 40 is nothing for a little hardy hole accessory. I can't do that.
Mike
