Re: Is it a Hardie orPritchel Hole
Posted by 36 coupe on January 28, 2018 at 19:35:13 [URL] [DELETE] :
In Reply to: Re: Is it a Hardie orPritchel Hole posted by BlasterStumps on January 22, 2018 at 00:04:01:
You can make a hardy from a grade 8 bolt.Run the nut up tight to the end of the thread then cut the head off the bolt.Grind the taper slowly.I have one vise that has a hardy hole in the anvil .Go easy with the hammer.You have to knick all around the stock and break it.Find a book on black smith work.A pritchel is a pointed tool used to make nail holes in hot horse shoes.
