Re: engine internals
Posted by Island Mike on January 04, 2018 at 21:46:44 [URL] [DELETE] :
In Reply to: engine internals posted by brownsmule on January 03, 2018 at 20:27:00:
Ar speedway circuits, the midgets ran 200 cubic inch engines. Which included the smaller Ford V8 60, as found in British Ford cars, and some others. All the major early engine guys, had hot rod parts for these engines. Edelbrok for instance. They ran them on alcohol. Cylinder heads, intake manifolds, cam shafts, pistons were the main fair. Some ran overhead valves. Some ran 3 carbs on each side entering the exhaust ports, while the exhaust ran out the old intake side.
In CA, in the early hot rod days, they used the 221 cubic inch engine for drags, and Bonneville. Some still stick with tradition, and still run flat head engines.
I have not idea about crossover parts. I did get close and personal with a friends midget. And many of the early hot rod guys. But just like Japanese motorcycle engines killed off the British, so did OHV and later OHC engines retire the side valve. Eventually Briggs and Strattan had to make OHV motors to compete with Honda.
Island Mike
