Re: Photobucket
Posted by Farmer Dan on December 05, 2017 at 17:53:47 [URL] [DELETE] :
In Reply to: Photobucket posted by Walt/Tx on December 05, 2017 at 15:59:33:
found this on a motorcycle forum I hang out on. Lets you see the picture instead of the ad. I'm using Windows 7Pro and Google Chrome and it seems to work just fine. Thought I would share if you want to give it a shot. Here is a copy of the post I read it from:
If you're using Google Chrome, go to the three dots on the right side of the screen and click them. A drop down should appear. Hover your mouse over "More Tools," and when the next drop down appears, click on extensions. Go to the link towards the bottom that says "Get more extensions." In the search box, type "Photobucket Fix," and hit enter. Click the install button and once it's done, you should be able to see photobucket pictures again.
For FireFox users, click on the three bars on the right side of the screen, then click on add ons. Click search for "photobucket hotlink" and click install. Same result.
Hope this helps.
