Re: Fairbanks moris
Posted by BlasterStumps on December 03, 2017 at 14:56:05 [URL] [DELETE] :
In Reply to: Fairbanks moris posted by Dave Smith on December 03, 2017 at 14:25:38:
It's probably all together the wrong method but, I would center punch the rivet, then using a small drill bit, drill about 3/16 deep , then step up the bit size to 1/8" or so to see if it loosens the top of the rivet. If you get the nameplate off, then just how to remove the rest of the rivet may be try twist it out with pliers or possibly drill more. Like I said, probably all together wrong. I have never attempted it so I'm simply guessing this will work.
Mike
