Re: Spark plugs
Posted by 36 coupe on November 13, 2017 at 16:17:20 [URL] [DELETE] :
In Reply to: Re: Spark plugs posted by Tim Daley(MI) on November 13, 2017 at 08:03:14:
I was cleaning a fence row picking up bits of barbed wire.Put the junk on the carry all.At one spot there was extra junk.The tractor idled a bit longer.When I tried to move the tractor it stalled.Started right up but no power to move.Gradually increased the engine RPM until it smoothed out.Then I could move to the dump area with the junk wire.JD tractors of the B series will stall if idled too long.It happens a lot on parade tractors.There is plenty of bad press on Mexico made champion plugs breaking off in cylinder heads.This was long before Ford had trouble with engines spitting spark plugs.In any case using H10s in Ford tractors will give plenty of fouling.
