Re: 9N Engines Offered in Ford trucks.
Posted by 36 coupe on September 20, 2017 at 06:12:37 [URL] [DELETE] :
In Reply to: Re: 9N Engines Offered in Ford trucks. posted by Gaspump on September 19, 2017 at 15:53:48:
If you look at the 9N parts book you will find many parts with car and truck part numbers.Pistons, rings, piston pins. spark plugs,ignition points,oil pumps.Front wheel bearings.Ring and pinions,differential bearings,tie rod ends.Steering wheels,tail lites.Timing gears.Starter and generator parts,Clutch,pressure plate,throw out bearings.I cant remember all but there are a lot more.
