Re: Hey Gaspump, do you have some high ground??
Posted by Gaspump on September 09, 2017 at 11:21:05 [URL] [DELETE] :
In Reply to: Hey Gaspump, do you have some high ground?? posted by steveVa on September 09, 2017 at 08:48:42:
Not high but house floor is 25' above sea level, near the river a couple of miles inland. Latest forecast is for 73mph winds here which is a little less than Mathew last Oct. Been cutting potentially hazardous limbs last two days and if forecast holds should be fine. Worst part is watching things blow and nighttime darkness til it passes and I can get the generator going, then the big job of cleanup. Still have some damaged trees left over from Matthew. Thanks for your thoughts.
