Primer/sealer
Posted by dave#1 on August 19, 2017 at 09:44:22 [URL] [DELETE] :
The wife caught a tree root with the rider and bent one of the blades almost 90 degrees! So, Off with the deck to service the blades and the 2 belts, Well, found a couple of cracks, welded them up, pressure washed and wire wheeled the deck, There's no way I can get all the rust off, So I'm looking for a good durable primer/sealer to prime the deck with, so my question to you guys....What do you use ? After its primed/painted I plan on coating it with a Teflon deck paint which I've used before and it works great?
Thanks
later,dave
