Re: test photo
Posted by Tim Daley(MI) on July 10, 2017 at 10:46:17 [URL] [DELETE] :
In Reply to: test photo posted by Patrick Knight (N.Cal) on July 10, 2017 at 00:42:08:
Patrick-
Just for future reference, when making a post that you aren't sure of whether your picture will appear correctly, or for whatever other reason, you can always do a pre-test by clicking the PREVIEW MESSAGE first instead of just the POST MESSAGE box. By previewing it first, you can see if it is what you intended, including spelling and punctuation, before you post it to the forum. If you have the html code set up right for a picture, the picture(s) will show up as intended. If something isn't right, you will get a red or black box [X] instead. Then you simply ARROW BACK <- to your reply/post and fix the problem then try a preview again. Once you get the problem fixed and your post appears as you want it to, then you click the Post Message button. You'll be asked to enter a new CAPTCHA code but so what...
hoping this helps...
